Works with Bricscad (Windows) Classic and Pro, Bricscad (Linux) Classic
Toggles the display of the scroll bars.
command bar: scrollbar
transparent: 'scrollbar
menu bar: View | Scrollbars
: scrollbar
WNDLSCRL is currently on: OFF/Toggle/<On>: (Enter an option.)
Scroll bars are useful for panning the drawing without using the Pan command:
The only reason to turn off scroll bars is to gain a bit more drawing area.
Turns off the scroll bars. |
Toggles the display of scroll bars:
Turns on the scroll bars. |
CommandLine - shows the command line.
CommandLineHide - hides the command line.
GraphScr - brings the graphics window to the foreground.
StatBar - toggles the display of the status bar.
TextScr - brings the text window to the foreground.
Toolbar and -Toolbar - toggle the display of toolbars.
