Works with Bricscad (Windows) Classic and Pro
Determines whether VBA macros are run.
command bar: security
menu bar: Tools | Security
: security
Choose a level of security, and then click OK.
This dialog box is necessary, because Microsoft's design of VBA applications allows use of destructive code, which can damage files on your computer.
VBA is short for Visual Basic for Applications; it is a programming language found in many Windows applications.
Only VBA macros listed as "trusted sources" will be run. Click the Trusted Sources tab to specify the names of trustworthy VBA macros. |
Bricscad displays a dialog box when a VBA macro runs. The dialog box allows you to choose whether or not to run the macro. |
All VBA macros are run. |
Lists the names of VBA macros that can be trusted. These are the only macros that will run when security is set to High. |
Removes the selected VBA macro from the list. |
Allows access to the VBA Project. |
AddInMan - loads and unloads VBA functions through a dialog box.
VbaLoad loads VBA projects.
VbaRun and -VbaRun - runs VBA macros.
