Returns a formatted date and time based on a given format.
$(EDTIME, time, format-phrase)
Assuming the date is 2009 March 04 09:37:06
| Format phrase | Result |
| D | 4 |
| DD | 04 |
| DDD | Wed |
| DDDD | Wednesday |
| M | 3 |
| MM | 03 |
| MON | Mar |
| YY | 09 |
| YYYY | 2009 |
| H | 9 |
| HH | 09 |
| MM | 37 |
| SS | 06 |
| AM/PM | AM |
| a/p | a |
| Code | Returns |
| $(edtime,$(getvar,date),H:MMam/pm) | 09:37am |
| $(edtime,$(getvar,date),DDD"," DD-MO-YY) | Wed 04-03-09 |
| $(edtime,$(getvar,date),DDD"," D MON"," YYYY) | Wed, 4 Mar 2009 |
When format phrase contains text that Diesel cannot interpret, it is displayed literally (e.g. a space, a colon(:)). To use a comma (,) within the format phrase, quote it "," so that Diesel does not read the comma as an argument separator. If any of the “AM/PM” phrases appear in the format phrase, the “H” and “HH” phrases will edit the time according to the 12 hour civil clock (12:00–12:59—1:00–11:59) instead of the 24 hour clock (00:00–23:59)
Supplying 0 as time value will return the current date and time. This avoids the call on $(getvar,date).
| Code | Returns |
| $(edtime,0,H:MMam/pm) | 09:37am |
| $(edtime,0,DDD","DD-MONTH-YYYY) | Wed, 4-March-2009 |
See also...
DIESEL functions| Bricscad™ is commercialized by Bricsys NV. Bricsys NV and Vondle NV are fully owned subsidiaries of Menhirs NV. Copyright © 2001- Menhirs NV - All rights reserved. |
