If the strings val1 and val2 are identical, the string returns 1; otherwise, it returns 0.
$(EQ, val1, val2)
The following expression gets the name of the current layer; if the name matches the string value stored in the USERS1 (USERS1-5) system variable, it returns 1. Assume the string "PART12" is stored in USERS1 and the current layer is the same. $(eq, $(getvar,users1),$(getvar,clayer))Returns 1
Examples
| Code | Returns | Remark |
| $(eq,30,30.0) | 0 | note $(=,30,30.0) evaluates to 1 |
| $(eq,10,a) | 0 | |
| $(eq,ABC,abc) | 0 | |
| $(eq,ABC,$(upper,abc)) | 1 | |
| $(eq,$(getvar,thickness),5) | 0 | when THICKNESS=5.000 |
| $(eq,$(fix,$(getvar,thickness)),5) | 1 | when THICKNESS=5.000 |
See also...
