Creates a member object and adds it to the appropriate collection. The syntax varies depending on which object is being created.
Syntax
For the following collection objects: DimensionStyles, Layers, Linetypes, SelectionSets, TextStyles, Views, and Viewports, use the following syntax:
For the Blocks collection object:
For the UCSs collection object:
Where:
Name is a string representing the name of the object to be created;
InsertionPoint is a Variant representing the coordinates where the Blocks Collection object will be added;
Origin is a Variant representing the coordinates where the UCS will be added;
Examples...
