Adds a 3DMesh given the coordinates and mesh information.
Syntax
Where:
object is one of the ModelSpace or PaperSpace collection objects or a Block object;
M and N are Long integer variables representing the size of the mesh (the dimensions of the point array);
Vertices are a series of Point objects specifying coordinate locations for each vertex of the mesh;
You can also input the number of vertices in each direction and their coordinates.
