Adds an Attribute Definition at the given insertion point and other attribute information.
Syntax
Where:
object is one of the ModelSpace or PaperSpace collection objects or a Block object;
Height is a double-precision variable representing the height (in drawing units) of the attribute text.
Mode is one of the following (acAttributeMode) attribute modes:
acAttributeModeNormal
acAttributeModeInvisible
acAttributeModeConstant
acAttributeModeVerify
acAttributeModePreset
Prompt is a string variable representing the text to be displayed to the user;
InsertionPoint is a Variant representing the location of the attribute;
Tag is a string variable identifying each occurrence of the attribute;
Value is a string variable representing the default value of the attribute.
