Sub AddCone_Example() ' This example adds a cone to the drawing using the AddCone method. Dim coneObj As Acad3DSolid Dim Pt1(0 To 2) As Double: Pt1(0) = 2: Pt1(1) = 2: Pt1(2) = 0 Set coneObj = ThisDrawing.ModelSpace.AddCone(Pt1, 3, 4) coneObj.Update ThisDrawing.Application.ZoomExtents End Sub
