Adds a 3 Point Angular dimension object.
Syntax
Where:
AngleVertex is a Variant identifying the center of the circle or arc, or the common vertex between the two dimensioned lines;
FirstEndPoint is a Variant identifying the point through which the first extension line passes;
SecondEndPoint is a Variant identifying the point through which the second extension line passes;
TextLocation is a Variant identifying the location of the text.
