Adds a raster image to the drawing.
Syntax
Where:
ImageFile is a string representing the full path and file name of the image;
InsertionPoint is a Variant identifying the point at which the image will be inserted;
ScaleFactor is a double-precision variable (or value) representing the raster image scale factor. The default image scale factor is 1. The scale factor must be a positive number.
RotationAngle is a double-precision variable (or value) representing the rotation angle in radians for the raster image.
Examples...
