Sub AddSphere_Example() ' This example adds a sphere to the drawing using the AddSphere method. Dim sphereObj As Acad3DSolid Dim pt1(0 To 2) As Double: pt1(0) = 0: pt1(1) = 0: pt1(2) = 0 Set sphereObj = ThisDrawing.ModelSpace.AddSphere(pt1, 4) sphereObj.Update ThisDrawing.Application.ZoomExtents End Sub
