Sub AddTorus_Example() ' This example adds a torus to the drawing using the AddTorus method. Dim torusObj As Acad3DSolid Dim Pt1(0 To 2) As Double: Pt1(0) = 0: Pt1(1) = 0: Pt1(2) = 0 Set torusObj = ThisDrawing.ModelSpace.AddTorus(Pt1, 20, 5) torusObj.Update ThisDrawing.Application.ZoomExtents End Sub
