Sub AddWedge_Example() ' This example adds a torus to the drawing using the AddWedge method. Dim wedgeObj As Acad3DSolid Dim Pt1(0 To 2) As Double: Pt1(0) = 0: Pt1(1) = 0: Pt1(2) = 0 Set wedgeObj = ThisDrawing.ModelSpace.AddWedge(Pt1, 3, 4, 5) wedgeObj.Update ThisDrawing.Application.ZoomExtents End Sub
