ArrayPolar method example
Sub ArrayPolar_Example()
Dim pt1(0 To 2) As Double: pt1(0) = 4: pt1(1) = 4: pt1(2) = 0
Dim pt2(0 To 2) As Double: pt2(0) = 7: pt2(1) = 1: pt2(2) = 0
Dim myLine As AcadLine
Set myLine = ThisDrawing.ModelSpace.AddLine(pt1, pt2)
myLine.Update
ThisDrawing.Application.ZoomExtents
Dim numOfObjects As Integer: numOfObjects = 6
Dim angleToFill As Double: angleToFill = 4.72
Dim ptBase(0 To 2) As Double
ptBase(0) = 4: ptBase(1) = 2: ptBase(2) = 0
myLine.ArrayPolar numOfObjects, angleToFill, ptBase
MsgBox "Polar array constructed."
End Sub
Bricscad™ is commercialized by Bricsys NV. Bricsys NV and Vondle NV
are fully owned subsidiaries of Menhirs NV. Copyright ©
2001- Menhirs NV - All rights reserved. |
