Creates a rectangular array.
Syntax
Where:
object is one of the ModelSpace or PaperSpace collection objects or a Block object;
NumberOfRows is the number of rows (horizontal elements) in the array;
NumberOfColumns is the number of rows (vertical elements) in the array;
NumberOfLevels is the number of levels in a 3D array;
GapBetweenRows is the distance between rows. A positive number causes the array to be built to the right of the source object, while a negative number causes the array to be built to the left.
GapBetweenColumns is the distance between rows. A positive number causes the array to be built upward, while a negative number causes the array to be built downward.
GapBetweenLevels is the distance between levels. A positive number causes the array to be expanded in the positive direction, while a negative number causes the array to be expanded in a negative direction.
Examples...
ArrayRectangular method example
