Attaches a specified drawing as an ExternalReference.
Syntax
Where:
object is one of the ModelSpace or PaperSpace collection objects or a Block object;
PathName is a string representing the full path and file name of the drawing;
Name is a string representing the name of external reference to be created;
InsertionPoint is a Point object representing the point at which the drawing will be inserted;
XScale, YScale, and ZScale are double-precision variables (or values) representing the scaling factors for the drawing along each coordinate plane;
Rotation is a double-precision variable (or value) representing the rotation angle (in radians) for the external reference;
bOverlay is a Boolean variable (or value) indicating whether the reference is an overlay or attachment
TRUE: The xref instance is an overlay.
FALSE: The xref instance is an attachment.
Examples...
AttachExternalReference method example
