Closes the document and all associated windows.
Syntax
Where:
object is a Document object.
SaveChanges is an optional Boolean variable indicating whether to save changes made since the last save (A value of True saves the changes, while a value of False does not);
File is an optional string naming the file to be saved.
Examples...
