Sub Delete_Example() ' This example creates a Layer named by the user. ' It then deletes the layer. Dim newLayer As AcadLayer Dim lName As String lName = InputBox("Type a layer name") ' Create the new layer Set newLayer = ThisDrawing.Layers.Add(lName) MsgBox "Layer " & newLayer.Name & " has been added." ' Delete the layer lName = newLayer.Name newLayer.Delete MsgBox "Layer " & lName & " has been deleted." End Sub
