Imports files in DXF and other supported formats.
Syntax
Where:
FileName is a string representing the name of the file to be imported.
InsertionPoint is a Point object (optional) representing the location to insert the file. A location of 0,0 is assumed if this parameter is omitted.
ScaleFactor is a double-precision variable representing the scale factor for the imported information. The default value is 1.0.
