IntersectWith method example
Sub IntersectWith_Example()
Dim plVertices(0 To 15) As Double
plVertices(0) = 1: plVertices(1) = 0
plVertices(2) = 1: plVertices(3) = 1
plVertices(4) = 2: plVertices(5) = 1
plVertices(6) = 2: plVertices(7) = 0
plVertices(8) = 3: plVertices(9) = 0
plVertices(10) = 3: plVertices(11) = 1
plVertices(12) = 4: plVertices(13) = 1
plVertices(14) = 4: plVertices(15) = 0
Dim oPline As AcadLWPolyline
Set oPline = ThisDrawing.ModelSpace.AddLightWeightPolyline(plVertices)
Dim oLine As AcadLine
Dim oPt1(0 To 2) As Double: oPt1(0) = 0: oPt1(1) = 1: oPt1(2) = 0
Dim oPt2(0 To 2) As Double: oPt2(0) = 5: oPt2(1) = 0: oPt2(2) = 0
Set oLine = ThisDrawing.ModelSpace.AddLine(oPt1, oPt2)
Dim vPoints As Variant
vPoints = oPline.IntersectWith(oLine, acExtendNone)
infoIntersections vPoints
End Sub
Private Sub infoIntersections(inPoints As Variant)
Dim i As Integer
Dim n As Integer
Dim sBuf As String
If VarType(inPoints) <> vbEmpty Then
For i = LBound(inPoints) To UBound(inPoints) Step 3
n = n + 1
sBuf = "Intersection Point" & n & " is: ( " & inPoints(i) & ", " & inPoints(i + 1) & ", " & inPoints(i + 2) & ")"
MsgBox sBuf, , "IntersectWith Example"
sBuf = vbNullString
Next
End If
End Sub
Bricscad™ is commercialized by Bricsys NV. Bricsys NV and Vondle NV
are fully owned subsidiaries of Menhirs NV. Copyright ©
2001- Menhirs NV - All rights reserved. |
