Mirror3D method example
Sub Mirror3D_Example()
Dim boxObj As Acad3DSolid
Dim length As Double, width As Double, height As Double
Dim center(0 To 2) As Double
center(0) = 5#: center(1) = 5#: center(2) = 0
length = 5#: width = 7: height = 10#
Set boxObj = ThisDrawing.ModelSpace.AddBox(center, length, width, height)
Dim ptMirr1(0 To 2) As Double
Dim ptMirr2(0 To 2) As Double
Dim ptMirr3(0 To 2) As Double
ptMirr1(0) = 1.25: ptMirr1(1) = 0: ptMirr1(2) = 0
ptMirr2(0) = 1.25: ptMirr2(1) = 2: ptMirr2(2) = 0
ptMirr3(0) = 1.25: ptMirr3(1) = 2: ptMirr3(2) = 2
Dim mirrorBoxObj As Acad3DSolid
Set mirrorBoxObj = boxObj.Mirror3D(ptMirr1, ptMirr2, ptMirr3)
Dim NewDirection(0 To 2) As Double
NewDirection(0) = -1: NewDirection(1) = -1: NewDirection(2) = 1
ThisDrawing.ActiveViewport.Direction = NewDirection
ThisDrawing.Application.ZoomExtents
End Sub
Bricscad™ is commercialized by Bricsys NV. Bricsys NV and Vondle NV
are fully owned subsidiaries of Menhirs NV. Copyright ©
2001- Menhirs NV - All rights reserved. |
