This example plots the current drawing to a file.
Sub Example_Plot() Dim oPlot As AcadPlot: Set oPlot = ThisDrawing.Plot Dim sPlotFileName As String: sPlotFileName = "c:MyPlot01.plt" Dim bPlotOk As Boolean: bPlotOk = oPlot.PlotToFile(sPlotFileName) MsgBox (IIf(bPlotOk, "Plot succeeded", "Plot failed")) End Sub
This example plots the current drawing to a file while using a named plot configuration.
Sub Example_Plot02() Dim oPlot As AcadPlot: Set oPlot = ThisDrawing.Plot Dim sPlotFileName As String: sPlotFileName = "c:MyPlot01.plt" Dim bPlotOk As Boolean bPlotOk = oPlot.PlotToFile(sPlotFileName, "Adobe_PDF.pc3") MsgBox (IIf(bPlotOk, "Plot succeeded", "Plot failed")) End Sub
