Scales the entity or members of a selection set by a given scale factor.
Syntax
Where:
object is a Bricscad entity;
BasePoint is a Variant (three-element array of doubles) representing the point about which the entity will be scaled;
ScaleFactor is a double-precision variable (or value) representing the factor by which to scale the entity or entities.
