Class AcadAcCmColor
Member of BricscadDb
The AcCmColor object represents colors. You can use the AcCmColor object to set colors and perform other color-related operations on objects.
This object can hold an RGB value, an ACI number (an integer from 1 to 255), or a named color.
| Methods | Properties |
| SetColorBookColor | Blue |
| SetNames | BookName |
| SetRGB | ColorIndex |
| ColorMethod | |
| ColorName | |
| EntityColor | |
| Green | |
| Red | |
