Class AcadDatabasePreferences
Member of BricscadDb
The DocumentPreferences object contains certain settings for the active document (drawing). The settings of a document that are saved in a drawing (not the registry).The DocumentPreferences object has no applicable methods, but can be accessed with the following properties:
| Properties |
| Application |
| ContourLinesPerSurface |
| DisplaySilhouette |
| MaxActiveViewports |
| Parent |
| RenderSmoothness |
| SegmentPerPolyline |
| SolidFill |
| TextFrameDisplay |
| XRefLayerVisibility |
