DisplayScrollBars property example
Sub DisplayScrollBars_Example()
Dim myPrefs As AcadPreferences
Set myPrefs = ThisDrawing.Application.preferences
Dim scrollBarStatus As Boolean
scrollBarStatus = myPrefs.Display.DisplayScrollBars
MsgBox "The DisplayScrollBars property is: " & scrollBarStatus
myPrefs.Display.DisplayScrollBars = Not (scrollBarStatus)
MsgBox "The DisplayScrollBars property is now: " & myPrefs.Display.DisplayScrollBars
End Sub
Bricscad™ is commercialized by Bricsys NV. Bricsys NV and Vondle NV
are fully owned subsidiaries of Menhirs NV. Copyright ©
2001- Menhirs NV - All rights reserved. |
