Documents property example
Sub Documents_Example()
Dim thisDocument As AcadDocument
Dim allDocuments As AcadDocuments
Set allDocuments = ThisDrawing.Application.Documents
Dim sBuf As String: sBuf = vbCrLf
For Each thisDocument In allDocuments
sBuf = sBuf & thisDocument.Name & vbCrLf
Next
If allDocuments.count > 0 Then
MsgBox "The loaded documents are: " & sBuf
Else
MsgBox "There are no loaded documents!"
End If
End Sub
Bricscad™ is commercialized by Bricsys NV. Bricsys NV and Vondle NV
are fully owned subsidiaries of Menhirs NV. Copyright ©
2001- Menhirs NV - All rights reserved. |
