Sub HistoryLines_Example() ' This example returns the current setting of HistoryLines. Dim myPrefs As AcadPreferences Set myPrefs = ThisDrawing.Application.preferences Dim iHistoryLines As Integer Set myPrefs = ThisDrawing.Application.preferences ' Retrieve the current GraphicsWinLayoutBackgrndColor value iHistoryLines = myPrefs.Display.HistoryLines MsgBox "The current value for HistoryLines is " & iHistoryLines End Sub
