Sub Layer_Example() 'This example returns the Layer property. Dim ents As Object Dim ent As AcadEntity Dim ct As Long Set ents = ThisDrawing.ModelSpace ct = ents.count Set ent = ents.Item(ct - 1) MsgBox "The Layer property for the last entity is: " & ent.Layer End Sub
