ObliqueAngle property example
Sub ObliqueAngle_Example()
Dim sText As String: sText = "Test string for ObliqueAngle property"
Dim insPt(0 To 2) As Double: insPt(0) = 0: insPt(1) = 9
Dim dHeight As Double: dHeight = 5
Dim textObj As AcadText
Set textObj = ThisDrawing.ModelSpace.AddText(sText, insPt, dHeight)
textObj.Update
ThisDrawing.Application.ZoomExtents
MsgBox "The ObliqueAngle is " & textObj.ObliqueAngle
textObj.ObliqueAngle = 0.785
textObj.Update
MsgBox "The ObliqueAngle is set to " & textObj.ObliqueAngle
End Sub
Bricscad™ is commercialized by Bricsys NV. Bricsys NV and Vondle NV
are fully owned subsidiaries of Menhirs NV. Copyright ©
2001- Menhirs NV - All rights reserved. |
