Origin property example
Sub Origin_Example()
Dim viewportObj As AcadViewport
Set viewportObj = ThisDrawing.ActiveViewport
Dim ucsObj As AcadUCS
Dim origin(0 To 2) As Double
Dim xAxisPoint(0 To 2) As Double
Dim yAxisPoint(0 To 2) As Double
origin(0) = 2: origin(1) = 2: origin(2) = 0
xAxisPoint(0) = 3: xAxisPoint(1) = 2: xAxisPoint(2) = 0
yAxisPoint(0) = 2: yAxisPoint(1) = 3: yAxisPoint(2) = 0
Set ucsObj = ThisDrawing.UserCoordinateSystems.Add(origin, xAxisPoint, yAxisPoint, "UCS1")
ThisDrawing.ActiveUCS = ucsObj
viewportObj.UCSIconOn = True
viewportObj.UCSIconAtOrigin = True
ThisDrawing.ActiveViewport = viewportObj
MsgBox "The origin of the UCS is: " & ucsObj.origin(0) & ", " & ucsObj.origin(1) & ", " & ucsObj.origin(2)
origin(0) = 4: origin(1) = 4: origin(2) = 0
ucsObj.origin = origin
MsgBox "The origin of the UCS is now: " & ucsObj.origin(0) & ", " & ucsObj.origin(1) & ", " & ucsObj.origin(2)
End Sub
Bricscad™ is commercialized by Bricsys NV. Bricsys NV and Vondle NV
are fully owned subsidiaries of Menhirs NV. Copyright ©
2001- Menhirs NV - All rights reserved. |
