TextString property example
Sub TextString_Example()
Dim sText As String: sText = "Test string for the AddText method"
sText = InputBox("Type some text here:")
Dim insPt(0 To 2) As Double: insPt(0) = 0: insPt(1) = 9: insPt(2) = 0:
Dim dHeight As Double: dHeight = 5
Dim oText As AcadText
Set oText = ThisDrawing.ModelSpace.AddText(sText, insPt, height)
ThisDrawing.Application.ZoomExtents
MsgBox "The text you entered is: " & oText.TextString
End Sub
Bricscad™ is commercialized by Bricsys NV. Bricsys NV and Vondle NV
are fully owned subsidiaries of Menhirs NV. Copyright ©
2001- Menhirs NV - All rights reserved. |
