Using modules
A module contains procedures, data and type declarations, and
definitions. Your VBA project does not need to include a module,
but there are advantages to doing so. By creating a module, you can
include multiple UserForms in your project and you can also run
your project as a macro from the Tools menu in Bricscad or by using
the VBARUN command.
To insert and use a module
- From the Insert menu in VBA, click Module.
- In the Properties window, type a name for your
module. (You can also accept the default name Module1,
Module2, etc.)
- Create code in the Code window just as you
would for your controls. Module-level code generally contains just
the general statements and macro assignments, as shown in the
following code:
Public myVariable as
Double
Sub anyMacro ()
UserForm1.Show
End Sub
Tell me about...
VBA (Visual
Basic for Applications)
Overview of automation
Starting
VBA
Inserting UserForms
Adding controls to a UserForm
Creating code
Managing VBA projects
Running a VBA program
Bricscad™ is commercialized by Bricsys NV. Bricsys NV and Vondle NV
are fully owned subsidiaries of Menhirs NV. Copyright ©
2001- Menhirs NV - All rights reserved. |
