Bricscad provides many editing tools for modifying a drawing. You can easily move, rotate, stretch, or change the scale of drawing entities. You can also make multiple copies of any entity and copy or move entities from one drawing to another.
If an entity is no longer needed in a drawing, you can delete it to remove it permanently from the drawing database.
You can modify most entities using general-purpose editing commands. Some complex entities require special commands to modify specific properties. Most of these tools and commands are located on the Modify toolbar and the Modify menu.
