Defining Attributes
Command: ATTDEF and -ATTDEF
The Attdef command defines how a block's attributes will be created through a dialog box.
The -Attdef command creates block's attribute definitions at the command prompt.
General procedure to define attributes:
To define an attribute
  1. Do one of the following:
  2. Click the Define Attributes... tool button () on the Tools toolbar.
  3. Choose Define Attributes...  in the Tools menu.
  4. Type attdef in the command bar, then press Enter.
The Define Attribute dialog opens.
  1. Define the Attribute:
  2. Type a name in the Tag field.
    The Tag Identifies each occurrence of an attribute in the drawing. The name you type in the Tag field can be any combination of characters except spaces. Lowercase letters are automatically converted to uppercase.
  3. Type a prompt in the Prompt field.
    The attribute prompt displays when you insert a block containing the attribute. If a prompt is omitted, the Tag is used as the prompt instead.
  4. Type a default value in the Default text field.
    For variable attributes, the default value is replaced by the actual value when you insert a block containing the attribute.
  5. Do one of the following:
  1. Click the OK button to define the attribute
    The Define Attribute dialog closes.
  2. (option) Right click to reopen the Define Attribute dialog, the repeat steps 2 and 3 to create another attribute.
