Works with Bricscad (Windows) Classic, Pro and Platinum, Bricscad (Linux) Classic and Pro
Displays the operating system Calculator.
command bar: cal
transparent: 'cal
: Cal
Enter numbers and operations, and then press =.
For scientific calculations, choose View | Scientific.
To close the calculator, click X.
Copy - copies results to the Clipboard, which can be pasted to Bricscad's command bar. Paste - pastes numbers from the Clipboard into the Calculator. |
Standard - displays basic calculator. Scientific - displays scientific calculator. Digit Grouping - adds commas to separate thousands, such as 1,234,456. |
Shell - access the command prompt of the operating system; runs Windows programs.
Files - displays the operating system's File Manager.
