Works with Bricscad (Windows) Classic, Pro and Platinum, Bricscad (Linux) Classic and Pro
Snaps to the quadrant points of circles, arcs, and polyarcs.
command bar: quadrant
transparent: quadrant
toolbar: Entity Snaps |
: quadrant
Displays no prompts in the command bar.
The quadrant points are located at the 90-degree points of circular entities:
When quadrant snap is on, the cursor snaps to the 90-degree points of circles, arcs, and polyarcs.
Quadrant |
Entering this command toggles Quadrant entity snap. It snaps to the 90-degree quadrant points on curved entities. This command can be entered transparently during commands, but must be entered without the apostrophe prefix ( ' ). |
OSnap - toggles entity snap modes in the Settings dialog box.
-OSnap - toggles entity snap modes in the command bar.
Aperture - sizes the aperture cursor for entity snaps.
2dIntersection - toggles apparent intersection snap mode.
3dIntersection - toggles intersection snap mode.
Apparent - toggles apparent intersection snap mode.
Center - toggles center snap mode.
Endpoint - toggles endpoint snap mode.
Extension - toggles extension snap mode.
From - allows to enter relative coordinates with respect to a reference point.
Insertion - toggles insertion snap mode.
Midpoint - toggles midpoint snap mode.
Mtp - allows to specify a point as the midpoint between two points.
Nearest - toggles nearest snap mode.
Node - toggles node (point) snap mode.
None - turns off all entity snap modes.
Parallel - toggles parallel snap mode.
Perpendicular - toggles perpendicular snap mode.
Quick - toggles quick snap mode.
Tangent - toggles tangent snap mode.
