Works with Bricscad (Windows) Pro and Platinum, Bricscad (Linux) Pro
Creates section planes of 3D solids; the results are region entities.
command bar: section
alias: sec
menu bar: Draw | 3D Entities | Section
toolbar: Solid | ![]()
: section
Select entities: (Choose one or more 3D solids.)
Entities in set: 1
Select entities: (Choose more 3D solids, or press Enter to continue.)
Specify first point on section plane or Object/Zaxis/View/XY/YZ/ZX: (Enter an option.)
Specify a point on the current view plane <0,0,0>: (Pick a point, or enter x,y,z coordinates.)
Section made in the current view plane:
Sections are made of regions, and can be manipulated as independent entities:
Specifies the entities from which the section is created. Choose one or more 3D solids; this command does not work with 2D regions. |
Pick a point to specify the plane in which the section lies; prompts you: Specify second point on plane - pick another point. Specify third point on plane - pick a third point (three points define a plane). |
Creates the section from entities that intersect the 3D solid; prompts you: Select a circle, ellipse, arc, 2D-spline, or 2D-polyline - choose an entity. You can also use elliptical arcs. The entity defines the plane through which to create the section.
Creates a section in the plane defined by one point on the plane, and a second on the plane's normal (z axis); prompts you: Specify a point on the section plane - pick a point to define the location of the section plane. Specify a point on the Z-axis (normal) of the plane - pick another point to locate the normal. |
Creates a section in the plane of the current 3D viewpoint; prompts you: Specify a point on the current view plane - pick a point to define the height of the section. This is probably the easiest of the options. |
Creates a section parallel to the x,y plane; prompts you: Specify a point on the XY-plane - pick a point to define the height of the section above or below the x,y plane. |
Creates a section parallel to the y,z plane; prompts you: Specify a point on the YZ-plane - pick a point to define the height of the section above or below the y,z plane. |
Creates a section parallel to the z,x plane; prompts you: Specify a point on the ZX-plane - pick a point to define the height of the section above or below the z,x plane. |
