Works with Bricscad (Windows) Classic, Pro and Platinum, Bricscad (Linux) Classic and Pro
Sets units of linear and angular measurements through the Settings dialog box.
command bar: units
transparent: 'units
alias: un, ddunits
status bar: X,y,z-coordinates
: units
Displays the Drawing Units section of the Settings dialog box:
Change settings, and then click the X button.
Specifies the units of linear measurement. Select a unit:
For metric units, choose 2 (decimal). |
Specifies the number of decimal places. Enter a number between 0 and 8:
This option affects the precision of fractions in architectural and fractional units:
Specifies the type of angular units. Select a unit:
Specifies the number of decimal places. Enter a number between 0 and 8. |
Specifies the direction for 0 degrees. The default is the positive x axis. Enter an angle. You can also rotate the drawing through the Snap command's Rotate option.
Toggles the direction in which angles are measured:
Right-click 72',42',0" (or other x,y,z coordinates) on the status bar for the shortcut menu:
Shortcut Menu |
Scientific Linear Units |
Chooses scientific as the working units. |
Decimal Linear Units |
Chooses decimal (metric) as the working units. |
Engineering Linear Units |
Chooses engineering as the working units. |
Architectural Linear Units |
Chooses architectural as the working units. |
Fractional Linear Units |
Chooses fractional as the working units. |
Relative |
Displays relative coordinates in the status bar. |
Absolute |
Displays absolute coordinates in the status bar. |
Off |
Displays coordinates only when points are picked. |
Properties |
Opens the Coordinates section of the Settings dialog box.
Coordinates
Specifies how coordinates are displayed in the status bar:
-Units - sets units through the command bar.
NewWiz - sets units and other parameters for new drawings.
New - starts new drawing in Imperial or metric units.
