Works with Bricscad (Windows) Classic, Pro and Platinum, Bricscad (Linux) Classic and Pro
Displays images saved as SLD or WMF files (short for "view slide").
WMF files are not supported on the Linux platform.
command bar: vslide
aliases: vs, vsnapshot
menu bar: Tools | View Snapshot
toolbar: Tools | ![]()
: vslide
Choose a file, and then click Open.
To remove the slide from the viewport, use the Redraw command.
Specifies the name of the slide file. |
Selects the file type of the slide file:
Displays the slide in the current viewport. Use the Redraw command to remove the slide. |
MSlide - saves drawings in SLD, EMF, and WMF formats.
Redraw - removes the slide from the viewport.
