Lisp: additional functions: VL..
vl-bb-ref
vl-bb-set
vl-bt
vl-bt-off
vl-bt-on
vl-catch-all-apply
vl-catch-all-apply-error
vl-catch-all-error-message
vl-catch-all-error-p
vlcatcherrp
vl-cmdf
vl-consp
vl-directory-files
vl-doc-export
vl-doc-import
vl-doc-ref
vl-doc-set
vl-enable-user-cancel
vl-every
vl-exit-with-error
vl-exit-with-value
vl-file-copy
vl-file-delete
vl-file-directory-p
vl-filename-base
vl-filename-directory
vl-filename-extension
vl-filename-mktemp
vl-file-rename
vl-file-size
vl-file-systime
vl-getcurrentdir
vl-get-resource
vl-getstartupdir
vlisp-compile
vlisp-export-symbol
vlisp-import-exsubrs
vlisp-import-symbol
vl-list*
vl-list->string
vl-list-exported-functions
vl-list-length
vl-list-loaded-lisp
vl-list-loaded-vlx
vl-load-all
vl-load-com
vl-load-reactors
vl-member-if
vl-member-if-not
vl-mkdir
vl-position
vl-prin1-to-string
vl-princ-to-string
vl-propagate
vl-registry-delete
vl-registry-descendents
vl-registry-read
vl-registry-write
vl-remove
vl-remove-if
vl-remove-if-not
vl-rmdir
vl-setcurrentdir
vl-some
vl-sort
vl-sort-i
vl-string->list
vl-string-elt
vl-string-left-trim
vl-string-mismatch
vl-string-position
vl-string-right-trim
vl-string-rigth-trim
vl-string-search
vl-string-split
vl-string-subst
vl-string-translate
vl-string-trim
vl-symbol-name
vl-symbolp
vl-symbol-value
vl-unload-vlx
vl-vbaload
vl-vbarun
vl-vlx-loaded-p
