Add method
Creates a member object and adds it to the appropriate collection. The syntax varies depending on which object is being created.
Syntax
For the following collection objects: DimensionStyles, Layers, Linetypes, SelectionSets, TextStyles, Views, and Viewports, use the following syntax:
objectVariable = object.Add(Name)
For the Blocks collection object:
objectVariable = object.Add(InsertionPoint,Name)
For the UCSs collection object:
objectVariable = object.Add(Origin, XAxisPoint, YAxisPoint, Name)
Where:
Name is a string representing the name of the object to be created;
InsertionPoint is a Variant representing the coordinates where the Blocks Collection object will be added;
Origin is a Variant representing the coordinates where the UCS will be added;
Xaxis and Yaxis are Vector objects representing the respective axes of the UCS.
Examples...
InsertBlock method example
