Add3dFace method
Creates a 3D face object and adds it to the drawing. Input parameters are: default (Null) or three to four vertices; the fourth vertex is optional.
Syntax
object.Add3DFace(Point1, Point2, Point3, Point4)
Where:
     object is one of the ModelSpace or PaperSpace collection objects or a Block object;
     Point1, Point2, Point3, and Point4 are Point objects specifying locations of the 3DFace corners.
Examples...
Add3dFace method example
