Add3dPoly method
Creates a 3D polyline and adds it to the drawing. Input parameters are vertices for the polyline.
Syntax
object.Add3DPoly(Vertices)
Where:
     object is one of the ModelSpace or PaperSpace collection objects or a Block object;
     Vertices are a series of vertices specifying coordinate locations for each polyline vertex.
Examples...
Add3dPoly method example
