Creates a new arc object and adds it to the drawing.
Syntax
Where:
objectVariable is an AcadArc object;
object is one of the ModelSpace or PaperSpace collection objects or a Block object;
Center is a Variant representing the center of the arc;
Radius is a double-precision variable or number representing the radius of the arc;
StartAngle and EndAngle are double-precision variables or numbers representing the starting and ending angles (in Radians) of the arc.
Examples...
© Menhirs NV. All rights reserved. |
