AddAttributeDef method
Adds an Attribute Definition at the given insertion point and other attribute information.
Syntax
objectVariable = object.AddAttributeDef(Height, Mode, Prompt, InsertionPoint, Tag, Value)
Where:
     object is one of the ModelSpace or PaperSpace collection objects or a Block object;
     Height is a double-precision variable representing the height (in drawing units) of the attribute text.
     Mode is one of the following (acAttributeMode) attribute modes:
     acAttributeModeNormal
     acAttributeModeInvisible
     acAttributeModeConstant
     acAttributeModeVerify
     acAttributeModePreset
     Prompt is a string variable representing the text to be displayed to the user;
     InsertionPoint is a Variant representing the location of the attribute;
     Tag is a string variable identifying each occurrence of the attribute;
     Value is a string variable representing the default value of the attribute.
