AddBox method
Adds a box given the origin, length, width and height. The box is drawn as a 3dSolid.
Syntax
objectVariable = object.AddBox(Origin, Length, Width, Height)
Where:
     object is one of the ModelSpace or PaperSpace collection objects or a Block object;
     Origin is a Variant identifying the origin of the box;
     Length is a double-precision variable representing the length of the box;
     Width is a double-precision variable representing the width of the box;
     Height is a double-precision variable representing the height of the box;
Examples...
AddBox method example
