Sub AddCircleExample() ' This example creates a circle with a radius of 4 and ' adds it to the drawing using the AddCircle method. Dim ctrPt(0 To 2) As Double ctrPt(0) = 1: ctrPt(1) = 2: ctrPt(2) = 0 Dim myCircle As AcadCircle Set myCircle = ThisDrawing.ModelSpace.AddCircle(ctrPt, 4) myCircle.Update ThisDrawing.Application.ZoomExtents MsgBox "Circle created w/ center point at 1,2.", vbInformation, "AddCircle Example" End Sub
© Menhirs NV. All rights reserved. |
