AddCone method
Adds a cone given the center, base radius, and height. The cone is drawn as a 3dSolid.
Syntax
objectVariable = object.AddCone(Center, BaseRadius, Height)
Where:
     object is one of the ModelSpace or PaperSpace collection objects or a Block object;
     Center is a Variant identifying the center of the cone;
     BaseRadius is a double-precision variable representing the radius of the cone at its base;
     Height is a double-precision variable representing the height of the cone.
Examples...
AddCone method example
