AddCylinder method
Adds a cylinder given the center, base radius, and height. The cylinder is drawn as a 3dSolid.
Syntax
objectVariable = object.AddCylinder(Center, Radius, Height)
Where:
     object is one of the ModelSpace or PaperSpace collection objects or a Block object;
     Center is a Variant identifying the center of the cylinder;
     Radius is a double-precision variable representing the radius of the cylinder;
     Height is a double-precision variable representing the height of the cylinder.
Examples...
AddCylinder method example
